Need one for my 1994 S4 and I am in Invercargill.
Not sure if anyone reads this forum anymore...
I'll have a look tonight. Have a box of relays cleaned out of cars I've dismantled.
Had a search around. Sorry none in my spares.
Maybe try Qualitats or local Bosch guy.
Thanks for looking - trying to avoid the $$ for dealer price.
can you post picture of pin layout and schemetic on the cover,have a heap of euro car relays,may just have one,dealer price could be mental.
Have you called the dealer?
Also are you 100% sure its the relay? My after run pump and fan were not working on my s6, turned out to be the wires to the sensor had broken.
@watercooled - here is link to flickr photo of my relay pins. No schematic on case. I have a used one coming from the states but if it shows up no good also, would be nice to have a back up plan. Let me know what you have. Dealer price is $175
http://farm4.staticflickr.com/3720/12043022333_38c1837303_o.jpg
@00quattro00 - yes, dealer price as above. diagnostic code says relay is bad - failed closed so fan runs all the time with key off and drains battery.
They are used in all of the old turbo cars and the b5 turbo cars. I can check on the weekend, should have one somewhere
Quote from: volcanoblack on January 20, 2014, 03:54:58 PM
This is an oddball ,switching to 87f not very standard fare it maybe has a built it timer or secondary control from a thermo switch ,relay prices suck as the less common ones cost a fortune,shame you have ordered one cause any a good auto lecky shop could maybe spec one dependant on brand,Hella have a good range for example.
@watercooled - I don't really understand all the electrics on this car (or most cars nowadays) but here is a post from Quattroworld forums with the circuitry.
http://forums.quattroworld.com/s4s6/msgs/252354.phtml
Local electric shops here in Invercargill are not that good with this car. Have tried with other issues and they are expensive for the subpar results I have gotten.
Cheers,
VB
If you're still looking for one, I have one on hand. Cheers.
Thanks but I got one from the States and a QuattroWorld forum member.
vb
