VOLKSWAGEN => Mk5 Golf - Jetta - Eos => Topic started by: Jasera on August 25, 2020, 07:35:58 pm
Title: Mk5 GTI - Battery Removal without turning off power supply?
Post by: Jasera on August 25, 2020, 07:35:58 pm
Hi All,
I need to do a DSG change on my MK5 which requires the battery and its housing to be disconnected.
However, I don't want to completely shut off the car power supply as this will void my tune (which I want to avoid due to the distance to travel + retune fee)
I understand this is not the safest thing to do of course, but has anyone got some ideas advice around this?
My plan would be to put a trickle charger at the end of the ground & live wires and disconnect the terminals which should keep it alive, and then carry out the service.
Thanks.
Title: Re: Mk5 GTI - Battery Removal without turning off power supply?
Post by: 80 Vert on August 25, 2020, 08:12:17 pm
No need, I never remove the battery or battery tray.
Easy enough to change filter without removing either.
Post by: superfueler on August 28, 2020, 10:46:21 am
Do you want to pull the whole gearbox out or just do a fluid and filter change?
