AUDI => A4 - S4 - RS 4 - A5 - S5 - RS 5 => Topic started by: Dondbg on July 11, 2017, 09:55:10 PM
Title: Lowering options for B7 2.0T avant Quattro
Post by: Dondbg on July 11, 2017, 09:55:10 PM
Guys.
What is the best place to go to to get a good deal on lowering a B7 in Auckland ?
Title: Re: Lowering options for B7 2.0T avant Quattro
Post by: GLIDN on July 11, 2017, 10:35:16 PM
depends.
Do you want a right job?
do you want it really low (coil overs),
or do you simply want the car lowered?
Post by: RS ZWEI on July 12, 2017, 09:42:50 AM
Quote from: Dondbg on July 11, 2017, 09:55:10 PM
Guys.
Lowering springs = no cert.
Coilovers = cert ($500+)
Post by: Dondbg on July 12, 2017, 09:49:10 AM
Quote from: GLIDN on July 11, 2017, 10:35:16 PM
depends.
Mine is none sline, I want to get rid of the 4x4 look, been trying to source some sline suspensions but can't find something good, so I don't want to it really low, I want to be sline hight just improve the look, thought to buy from ecs or euro parts but shipping is insane so I guess I can find a better deal here in nz.
Can you point me to where mate ?
Post by: Dondbg on July 12, 2017, 09:50:48 AM
Quote from: RS ZWEI on July 12, 2017, 09:42:50 AM
Which coileovers ? STs, H&R ....? I don't think so :)
I guess JOMs will fit this figure which I'm happy to use. It can't find where to buy it from in nz
Post by: RS ZWEI on July 12, 2017, 09:55:11 AM
Quote from: Dondbg on July 12, 2017, 09:50:48 AM
Just get some lowering springs, I personally like H&R's.
Post by: McDoof on July 12, 2017, 11:20:35 AM
I think he meant you still need to add another $500 to your coilover price to get the cert done afterwards, so you would be looking north of $2k for a decent setup.
Post by: RS ZWEI on July 12, 2017, 12:10:19 PM
Quote from: McDoof on July 12, 2017, 11:20:35 AM
Correct.
Post by: 00quattro00 on July 12, 2017, 12:30:52 PM
You can buy D2 coiloivers brand new here for $500
Post by: schattenblau on July 12, 2017, 01:21:36 PM
why would you want to ?
back in my jdm days, d2 were rubbish
have they improved over the years ?
Post by: Dondbg on July 12, 2017, 10:21:07 PM
Quote from: RS ZWEI on July 12, 2017, 09:55:11 AM
Thought about that and it's easy upgrade but it will expedite the stock shocks wear.
Have you done it ? How long it's been?
Post by: Dondbg on July 12, 2017, 10:23:23 PM
Why do I need a cert ? If I got a decent H&R or ST kit.
Post by: 00quattro00 on July 13, 2017, 07:55:37 AM
Quote from: schattenblau on July 12, 2017, 01:21:36 PM
Seeing as he said JOMs would be fine the D2 are 1000x better than those
Post by: McDoof on July 13, 2017, 08:40:48 AM
Quote from: Dondbg on July 12, 2017, 10:23:23 PM
You don't need a cert if you are just doing a fixed height replacement. So you can do struts and/or springs without needing to cert the drop. Unless of course you end up putting in something like adjustable camber plates.
Post by: Dondbg on July 13, 2017, 09:49:24 AM
Quote from: 00quattro00 on July 13, 2017, 07:55:37 AM
Anyone using JOMs ? I hear good things about it
Post by: Dondbg on July 13, 2017, 09:51:26 AM
So guys. Where to go in auckalnd?
Post by: McDoof on July 13, 2017, 09:58:40 AM
Where are you based?
Hennie (GLIDN) is on the north shore. He can hook you up.
Post by: GLIDN on July 13, 2017, 10:03:29 AM
if you are after ST shock kit or coil overs?
I can provide KW and a few others as well.
This I can most certainly assist with.
For everyone else, coil over certification costs $790 now
I have a car booked in next week for an LVV cert.
Post by: Dondbg on July 13, 2017, 06:10:09 PM
Quote from: GLIDN on July 13, 2017, 10:03:29 AM
I'm after a shock and spring kit to keep the cost down and I'm not after a crazy drop mate , I want an sline hight. What can you offer here ?
Just to confirm : when I need a certification ? Only if I go really low ?
Post by: le mans on July 14, 2017, 11:10:19 AM
Cert required if less than 100mm ground clearance, or if the height is adjustable: http://www.lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf (http://www.lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf)
So a small drop using lowering springs should be fine.
Post by: GLIDN on July 14, 2017, 04:05:33 PM
Quote from: le mans on July 14, 2017, 11:10:19 AM
As Le Mans pointed out,
If a structural part of the vehicle is below 100mm from the ground. Even with Lowering springs.
The vehicle would require LVV.
Post by: Dondbg on July 16, 2017, 09:27:28 AM
Make sense.
I'm after suspension kits with fixed hight That is not below 100mm so below doesn't apply :)
What options are avaible in Nz to acuhive like 30mm drop, I'm looking for spring + shock kit.
Thanks guys.
Post by: DTM on July 16, 2017, 04:06:45 PM
Just to understand what is a legal drop  and how many mm.?
I've never come across one must have a certificate if the car is lowered. I can understand that certain drops must be within certain ranges maybe where I used to come from all this doesn't exist cause no one was monitoring it or there was no legislation in place stipulating what is a safe drop and what's regarded as overboard such as bagging.
Post by: le mans on July 16, 2017, 05:49:54 PM
The thresholds are in the link above (steering and suspension). Anything that exceeds the threshold and has not been certified by the LVVTA should fail a wof inspection.
Post by: GLIDN on July 17, 2017, 09:00:10 AM
I can't find the link right now,
But found some H&R springs on trade me for $280-350. Again can't exactly remember price I saw.
Have a quick search.
Post by: GLIDN on July 17, 2017, 09:04:04 AM
Quote from: DTM on July 16, 2017, 04:06:45 PM
That depends on what was mentioned earlier that no structural part of the vehicle is lower than 100mm.
Each car is different.
For example, A tiguan with 300mm off the ground, could in theory be lowered as much as 200mm.
But a car that has 120mm off the ground, 20mm or less lowering kit, taking into account the spring settling height.
Post by: NZSPQ on July 21, 2017, 10:47:49 AM
Hi, my 2cents worth :)
https://www.kwsuspensions.com/products.html
I have KW v2's for the S5 and the Coupe - great ride.
Post by: Dondbg on August 29, 2017, 03:31:31 PM
I heard that if you got coilovers installed then you must get a certificate
Find hard to believe and yet and I can confirm it's true.
Anyone ?
Post by: RS ZWEI on August 29, 2017, 03:37:07 PM
Quote from: Dondbg on August 29, 2017, 03:31:31 PM
Anyone ?
This is correct. And you can only adjust the height +/- 5%.
These days certs are $700ish.
Post by: Dondbg on August 29, 2017, 06:15:45 PM
Quote from: RS ZWEI on August 29, 2017, 03:37:07 PM
Even if the ground clearance is above 100mm still cert is required !?!
This is a ripoff , WTF $700 for someone to have a look at a German certified coils and stick a plate... fffak
Post by: 00quattro00 on August 29, 2017, 06:23:31 PM
The whole cert system is a scam
