VOLKSWAGEN => Mk2 Golf - Jetta - Corrado => Topic started by: RevHappy on September 14, 2012, 12:03:11 AM
Title: Mk2 Digi2 9a
Post by: RevHappy on September 14, 2012, 12:03:11 AM
Hey guys
In need of some Tech advice
Now i know a couple of you out there have done this and it may be a walk in the park.
I will be getting underway with my 9a conversion in the coming weeks and have been studying like crazy as i am a bit dawnted by it. From my understanding the digi2 system will run it just fine (not perfect but fine) my 8v g/box will fit and everything else should be a plug and play. There are just a few things, online most speak of changing the fuel rail to a aftermarket one??? Also i read ages ago that a saab or volvo dizzy was needed, yet now when i read online it says the 9a one will sufice. Any light to be shed on these? Also how necessary is the oil cooler?
Cheers for your help in advance.
Title: Re: Mk2 Digi2 9a
Post by: johnp on September 14, 2012, 07:09:54 AM
I am currently running a 9A on digi with KR head and cams.
It is slow. Runs fine, idles fine, runs slow.
I have driven another Mk2 of a vask owner with ABF and original DIG 3.2 injection., Difference was almost night and day.
My conclusion, contrary to what you read on the net re digi 2 conversions,  is although you can get it to run fine on DIGI 2, it will be considerably down on power it should potentially have.
I am changing to KR K-jet in the next couple of weeks so will post the difference.
Post by: 00quattro00 on September 14, 2012, 08:56:35 AM
Quote from: gtimanik on September 14, 2012, 12:03:11 AM
Hey guys
Dont use digi and dont use a saab dizzy, just use the 9a kjet and ecu, its only a few wires that need hooking up
Post by: BB on September 14, 2012, 10:04:17 AM
He will have to fit the whole K-jet fuel pump and fuel lines and everything tho as his car is obviously a digi mk2.
Is this what you are doing JohnP?
Do you have the whole 9a fuel system and ecu and wiring loom manik?
I actually think you wanted to be called gtimaniac did you?
Post by: 00quattro00 on September 14, 2012, 10:39:40 AM
heres the files I used when I did my 9a 4 years ago
Post by: 00quattro00 on September 14, 2012, 10:40:05 AM
and
Post by: deedub on September 14, 2012, 11:36:20 AM
JohnP is your digi 9A with a standard ECU or have you got one of the plug in chips that you can buy that re-maps the fuelling?
Post by: johnp on September 14, 2012, 12:12:41 PM
Quote from: deedub on September 14, 2012, 11:36:20 AM
I have tried standard but currently have a "digifast" chip.
I was going to look at a chip that Nuespeed sell specifically for the 9A conversion,  but for the cost I am changing over to KR K-jet.
I have plots that show this outperforms any other system, chipped or KE motronic, even an ABF with KR K-jet will outperform  the ABF with standard Digi 3.2.
My previous 9A conversion ran Ke-motronic (std B3 9A Passat injection) and this definetly went better than the DIGI2  set up I now have.
My advice to gtimanik is to run the 9A Ke-motronic if he has it,  or IF, big if,  he can get his hands on a complete KR K-jet system, to do that.
Post by: johnp on September 14, 2012, 12:14:21 PM
Quote from: 00quattro00 on September 14, 2012, 08:56:35 AM
I agree, if he has this system, use it. My previous 9A conversion ran the KE-motronic and ran much much better as far as acceleration and top end were concerned.
Post by: BB on September 14, 2012, 01:30:15 PM
It may be so that a KR K-jet ABF could be very slightly faster but the system has other weaknesses and you economy will not be as good as if you keep your ABF on the digi 3.2.
This however has little to do with what maniac needs to know.
It is a shame so many people buy the engines without getting all the other stuff they need.
It would seem that the fitting of a 9a into a already K-jet golf is the best cheapest easiest way to go.
Or buy a complete ABF engine with loom and ecu and fit to either a digi or K-jet golf.
I still have a complete ABF engine with loom and ecu I would sell. $1000ono
If it does not sell it will find its way into my new mk2 golf one day.
Post by: johnp on September 14, 2012, 03:34:26 PM
Quote from: BB on September 14, 2012, 01:30:15 PM
BB, the 8V Kjet is not the same as 16V K-jet. The fuel distributor is different, the cone shape is different so the fueling is not the same.
Also the 16V k jet has a seperate control unit for the ignition map. I do not think standard 8v k-jet on a 16V would be much better than 8v digi 2.
And I am circumspect about the Saab dizzy after your story some time ago re the targa guy running this set up and his engine being destroyed from detonation.
K-jet is just as economical as digi 2 from my experince. Digi 2 is all about emissions.
Post by: BB on September 14, 2012, 04:12:46 PM
True true but then you always hear stories that a k-jet unit can run up to 300hp.
They must be BS stories.
I guess it would be easier to fit the 9a k-jet fuel unit to a 8v k-jet golf tho as you don't have to do the fuel pump, and the bits would pretty much swap out.
Add the ignition ECU and broom a Passat powered golf.
Kr k-jet units are quite rare.......mostly found in 16v powered golfs already >:D
I like the KR motor better than the 9a I think.
Post by: cpncrash on September 14, 2012, 07:52:08 PM
Agree with Basil and JohnP on this one (Tho I have never been in a digi powered 16v)
I first ran my 9a on the Passat K Jet (Motronic) and it ran pretty good apart from some idle issues
Changed the head to ported with KR cams - Got better
Then changed to KR Injection from a 16v Golf and it was a wee bit better again. I feel it goes ok but have never driven anything to compare against.
I had an auto 9a passat once and it went really hard!! wish I had kept the setup, it runs well when its all running well...... haha
And Agree with BB that KR engine are great they just have a nice pull to them over the whole range. I really liked my 16v GTI golf.
Post by: cpncrash on September 14, 2012, 07:53:40 PM
Quote from: johnp on September 14, 2012, 07:09:54 AM
Be good to hear how you get on John. Good Luck, tho its pretty straight forward conversion I'm sure you will be fine..... :)
Post by: cpncrash on September 14, 2012, 07:57:13 PM
GTimanik
I will probably still have a full B3 passat injection system sitting in the garage (I cannot confirm this until I have a decent look thru all the bits from over the years)
If your interested let me know
Running it on digi might be a good way to get it up and running quickly tho I'm not sure how much work would be involved.
Post by: RevHappy on September 14, 2012, 08:06:05 PM
Wow didnt expect this much response, cheers guys.
To clear confusion my name is Will, Gtimanik is just a username, call me Will if you want
I bought the engine off Deedub(dave) and he has just given me the motor so i had always planned to run it on digi. I would like to run it on digi just to get it going. Nothing is permanent.
What are peoples experience with the fuel rail? what one do i need?
Do i just run the 9a dizzy?
And the oil cooler question???
Post by: 00quattro00 on September 14, 2012, 08:43:42 PM
Quote from: gtimanik on September 14, 2012, 08:06:05 PM
You will need to buy a fuel rail, you could build your self up a basic megasquirt ecu quite cheaply
Post by: 00quattro00 on September 14, 2012, 08:55:16 PM
or just go with a 1.8t, its quite an easy conversion having just finished mine
Post by: RevHappy on September 14, 2012, 09:14:21 PM
Quote from: 00quattro00 on September 14, 2012, 08:55:16 PM
or could just park up mine and buy yours :P
What sort of fuel rail should i buy?
Post by: 00quattro00 on September 14, 2012, 09:22:41 PM
Quote from: gtimanik on September 14, 2012, 09:14:21 PM
I bought a cheap one off ebay when i was going to convert mine to efi, it was ok for the price
Post by: RevHappy on September 14, 2012, 09:41:32 PM
Quote from: 00quattro00 on September 14, 2012, 09:22:41 PM
Awesome cheers mate
Post by: RevHappy on September 14, 2012, 10:12:35 PM
is this what your talking about http://www.bahnbrenner.com/vw_audi/products/495/BBM_Billet_16V_Fuel_Rail_Kit
Post by: BB on September 14, 2012, 10:36:59 PM
If you don't have the ignition ecu and loom for the 16v 9a dizzy you have an issue.
The 9a dizzy has possibly only one cut out like the ABF I'm not sure, but even if it has 4 it has no advance weights or vacume.
That's where a Saab dizzy with vacume and weights and 4 cut outs comes into it.
Does the digi rail not fit at all? What rail did you use JohnP?
What oil cooler question?
Post by: RevHappy on September 14, 2012, 10:39:45 PM
This has been my main spot of reading http://forums.vwvortex.com/showthread.php?1648969-16v-Digfant-II-FAQ
it says in there that a aftermarket rail will be needed
do i need to fit a oil cooler or is it not much of a worry
Post by: 00quattro00 on September 14, 2012, 11:04:05 PM
Quote from: BB on September 14, 2012, 10:36:59 PM
The 9a dizzy is a 4 window and is locked ie no vacuum or weights, the saab dizzy is no good as it doest have the correct ign advance curve.
Do you have all the bits you need for the 9a? If you dont I have a couple of spare fuel distributors, ecus, injectors and lines
Post by: johnp on September 15, 2012, 09:21:35 AM
You can make your own fuel rail, or buy one off the net from the states. A couple of places do them.
BB can tell you about a Niissan fuel rail you can use.
Yes you use the 9A dizzy, modify your existing DIGI2 loom, you do not need any other loom.
If I were you I would buy the 16V 2.0l DIGI 2 chip from Nuespeed. Would probably then run fine.
Post by: 00quattro00 on September 15, 2012, 09:24:54 AM
And its a good time for buying atm
Post by: BB on September 15, 2012, 09:59:59 AM
Oh yea there was a golf 9a we fixed that had a Nissan sr20 fuel rail.
And yes If your car is a digi which it is you can just use the 9a dizzy with the ECU you have already.
What mods do you need to do to the loom tho John?
And then once you have it going then get the Neuspeed chip or you will be down on power as the 8v digi system really is about efficency and does not really gas it enough.
Its the K-jets that need the saab dizzy, which may not have exactly the right curves but it is for a 2l motor so will run it fine. The car that detonated was being driven extremely hard on a Targa and other things went wrong as well that added to the piston melt down.
I think the 9a has a oil cooler on the oil filter and should have the hoses all there so just leave it as it is.
Post by: johnp on September 15, 2012, 10:43:20 AM
Quote from: BB on September 15, 2012, 09:59:59 AM
Loom mods are essentially lengthening to get to the various sensors and fuel injectors. Its all very easy once you have a fuel rail.
You will need to change out the injector cups in the inlet manifold as they are not the same. Order new Digifant 2 injectors from the dealer, they a cheap enough, I have never had any success getting the DIGI2 plastic ones out of an 8V manifold.
Post by: watercooled on September 15, 2012, 01:18:53 PM
Conversion fuelrails are around stateside ,read a full article on it and they only come alive with the chip,standard Diji 2 has and an ecu with tame ignition setting and fuel mapping and the engine doe's run lean,the chip I'am running was really noticeable in my otherwise stock 89 when I had that.
I know that the conversion I read about produced good power for the owner,PM me and I will try and find the link its really well done.
The chip I'am running came from a guy in the UK ,he can custom map according to mods done as all his work is down using a rolling road.
My chips makes the bottom end smoother from idle up to 3000 and then it really kicks in.
Post by: RevHappy on September 15, 2012, 06:43:39 PM
Quote from: watercooled on September 15, 2012, 01:18:53 PM
Sweet cheers mate will probably head down the line of the nuespeed chip
Was it just a standard sr20 de rail or sr20det? know a couple guys around chch that specialise in silvia's and gtir's
Post by: BB on September 15, 2012, 08:47:16 PM
Standard Sr20.
All this 16v talk got me going so I ripped out my 8v digi motor and sub frame from the mk2 and gona get on with fitting my ABF.
Will have to pull my dash again but that's so easy on a mk2. Gona fit the mk3 fusebox and front loom complete. But not airbags or ABS.
Post by: watercooled on September 15, 2012, 10:00:29 PM
The reason for chipping is that the flow of the 16v way exceeds any thing you can do to a 8v head period,a good set-up 8v chip will help and you can adjust the stock diji afm to help or go for a 2e afm(worked for me)
Sorry BB but the Saab dizzy won't cut the mustard,as mentioned there are ignition curve problems ,the loom and wiring is up to you and no differant to what i've just done,like anything'' if you have done it its easy ''.
Make a wise decision regarding ce 1 and ce2 loom for your car ,getting a ce1 to work on diji 2 is less work than a loom change,but will make it easier if you don't have much wiring experience.
Basically (sounds easy ;)) presuming your car is k-jet?,if you retain ce1 loom you need to repower the fuel pump,use the warm up regulator feed for that,you need to wire in a basic relay to power your ecu this feeds off the "key on" side of the fuseboard,earth to body,relay feed output 87 to wiring under the scuttle near the heater inlet.
There are issues with other stuff like temp sensor repositioning and extensions to the stock diji ecu loom ,don't be put off,besides there too many digi haters on here :laugh: :laugh: :laugh:
Post by: RevHappy on September 16, 2012, 12:35:53 AM
Sorry forgot to mention, car is standard 8v digi2 at the moment. 89 mk2. Talked to a mate today and hes going to get hold of a sr20 fuel rail for me. i know i need to extend the injector wires but will be using the 9a dizzy as it says online to use it with the digi2 8v hall sender so will give that a go.
Will start not this week, am coming up to Auckland for 3 days  (Tue,Wed,Thur) so once im back in chch i will start on the Friday night/Saturday.
Out of interest....JohnP are you in Auckland? When im in auck next week could i come have a look at your set up? or does anyone want to come have a beer at a pub and talk some s*** about the conversion, wouldnt mind meeting some of the almighty wise ones of the north.
Will
Post by: watercooled on September 16, 2012, 08:12:46 AM
Quote from: gtimanik on September 16, 2012, 12:35:53 AM
Will
Will thats great,you are a few steps ahead in that case,you will have to extend some wires but it will be 90% plug and play.
Try this for info - google '' vwvortex 16v digifant II faq",great stuff on there,cheers Dean
Post by: johnp on September 16, 2012, 08:55:40 AM
Will
Yes I am in Auckland. You can give me a call when you are here. P-mail sent with my contact.
You do not need to change the hall sender in the dizzy.
All the hall devices themselves are the same, 8V, 16V.
Post by: BB on September 16, 2012, 09:47:17 AM
Yes your digi dizzy plug will plug straight into the 9a dizzy and work.
The Saab dizzy is used for k-jet conversions and they work, Andy balls ran his 9a on one as have many others. They come from a similar 2l motor and are fine for most driving.
Yes it is better to use the 9a ignition ecu and k-jet system but as with Will many only get the motor.
But it is simple, fit the 9a motor with the 9a dizzy. Fit the SR20 rail and plug all your existing wiring to dizzy and change the plug to suit the new rail.
The car will now run but be gutless.
Get a spare Digi ECU (I have one) send it to get a proper 9a conversion chip, plug back in and whammo your fueling and spark will be just right to get the best from the new motor.
Will your welcome to come visit me and get a spare digi ECU, we will get JohnP over and go down to Joys Cafe for a bite to eat.
Post by: RevHappy on September 16, 2012, 10:44:02 AM
Quote from: BB on September 16, 2012, 09:47:17 AM
S*** mate, cheers. Thats everything i was asking for. As for the spark and fueling tuning. Can this be done by a chip or is it best to send a whole ecu. And is it a job for specialists? ie platinum? or could Volksworld in chch give it a go?
Post by: johnp on September 16, 2012, 03:15:19 PM
Quote from: gtimanik on September 16, 2012, 10:44:02 AM
Do what I p-mailed you. It will then cost you FA.
Post by: BB on September 16, 2012, 08:13:25 PM
It sounds like there are special 9a chips for the digi2 ECU you will have to shop around and ask and they will cost a bit and need to be put in by somebody who knows what they are doing.
Or do what JohnP has said.....which is what?
Post by: johnp on September 16, 2012, 08:19:50 PM
Quote from: BB on September 16, 2012, 08:13:25 PM
Can't say. ;)
Post by: 00quattro00 on September 16, 2012, 08:20:50 PM
Buy his setup off him?
Post by: watercooled on September 16, 2012, 09:15:45 PM
There not hard to fit,common sense applied ,careful work and an anti-static wrist strap all good.
Post by: RevHappy on September 16, 2012, 09:54:01 PM
Quote from: watercooled on September 16, 2012, 09:15:45 PM
I put in my eprom about 2 years ago. so this will be the same.
Post by: deedub on September 17, 2012, 09:11:01 AM
Will sorry I couldn't make it on Sunday. I have a BBM fuel rail with the parts I have for you. You can use digifant injectors with it.
Post by: RevHappy on September 17, 2012, 10:53:27 AM
Away sweet when can you make it? When are you heading away?
Post by: RevHappy on October 25, 2012, 08:24:06 PM
bit of a update. Have ordered all the parts i need. Chip arrived yesterday :), will be pulling the motor over the next few weeks and my painter is gonna come paint the bay once its all cleaned. Just have leads left that i need to get. Also have a big question for you tech wizz's. What size wheel bearings go into the passat GT hubs? gonna put the big brakes on when i put it all back together and want new bearings, but dont have vernier calipers
Post by: 00quattro00 on October 25, 2012, 08:27:35 PM
75mm for the wheel bearings I believe,
Post by: RevHappy on October 25, 2012, 09:33:32 PM
cheers mate
Post by: RevHappy on October 28, 2012, 11:24:32 AM
Now that all the parts are on there way except the leads, i started on stripping the front yesterday. only got a hour and a half in on it but still happy with the effort on it. if i get time today might get the motor all the way out.
Post by: RevHappy on October 28, 2012, 07:39:07 PM
Got the rest of the motor out today
Post by: BB on November 01, 2012, 05:36:15 PM
Ive got something that resembles that at my place.
Post by: RevHappy on November 01, 2012, 06:14:33 PM
its feels good starting on it but i hope i keep it up
Post by: BB on November 01, 2012, 06:54:22 PM
Its a shame that pulling them all apart is the easy bit :P
Post by: RevHappy on November 01, 2012, 08:13:39 PM
yea but the joy of driving it is the fun part
Post by: BB on November 02, 2012, 09:36:16 AM
Well yea, so you better do the hard part which is making it go again so you can do the fun part ;)
Post by: RevHappy on November 03, 2012, 01:42:31 PM
Yup engine bay is being painted today
Post by: watercooled on November 04, 2012, 11:28:52 PM
Why the full front off?,did my transplant with the front on and found the bumper a nice place to part my butt ;D ;D ;D painting  ??? ??? anyway its up to you.
As Jem say's just get the car running and enjoy ,great to see another mk2 getting up and happening.
Love those steelies didn't you have cups on before that?
Post by: RevHappy on November 05, 2012, 02:24:27 PM
Pulled the front off cause didn't have a Crane and guards off cause inner guards are getting chip guard blacked. I used to hacker abt 16x7 but they where too big so swapped them
Post by: BB on November 05, 2012, 02:44:34 PM
Takes an hour to pull the front off makes for an easy job.
Post by: RevHappy on November 05, 2012, 03:12:46 PM
Yup and then don't need to mask it out
Post by: watercooled on November 07, 2012, 10:51:46 AM
Yea true,I'am lucky I guess have a large tree in the yard and good sturdy shed beams.
What stage are you @ with the diji conversion?did you check the 16v digi FAQ on Vortex?.
I reckon with the right chip it will work,also release your AFM spring 3 notches and that works good along with the chip also.
Post by: RevHappy on November 07, 2012, 08:32:48 PM
Quote from: watercooled on November 07, 2012, 10:51:46 AM
Yea bought a digi 16v 2l chip from techtonics. AFM was released a while ago to squeze all i could out of the 8v. Didnt get any work done tonight but yesterday got the box,motor and p/s rack cleaned ready for paint. cant wait. hopefully have it running next weekend
Post by: RevHappy on November 24, 2012, 07:45:01 PM
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fi1069.photobucket.com%2Falbums%2Fu461%2Fwtucker91%2F20121121_185446.jpg&hash=c2cc7ec3a641f796b1211afece751d30595cf3c6)
Post by: RevHappy on November 24, 2012, 07:50:13 PM
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fi1069.photobucket.com%2Falbums%2Fu461%2Fwtucker91%2F20121117_163808.jpg&hash=a20b7a40171008c69d6f498cb3524b7da3766a88)
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fi1069.photobucket.com%2Falbums%2Fu461%2Fwtucker91%2F20121117_163756.jpg&hash=6bdb1dde80ef49714ce3aa31f710716eb82ae8c8)
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fi1069.photobucket.com%2Falbums%2Fu461%2Fwtucker91%2F20121117_163744.jpg&hash=a27042211de8dd84a18be308f35925f7b159e438)
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fi1069.photobucket.com%2Falbums%2Fu461%2Fwtucker91%2F20121117_163738.jpg&hash=9010636b53f9451acab1faa0310b6bc9e66145a7)
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fi1069.photobucket.com%2Falbums%2Fu461%2Fwtucker91%2F20121117_163729.jpg&hash=77aca2eaf6d9b1d676a7044c248254e8a9801b31)
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fi1069.photobucket.com%2Falbums%2Fu461%2Fwtucker91%2F20121121_185452.jpg&hash=a10e85d8491bf77cdeea9683da8204ef61db576d)
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fi1069.photobucket.com%2Falbums%2Fu461%2Fwtucker91%2F20121124_190506.jpg&hash=3704351ed896874a12f535285a59bf959828e217)
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fi1069.photobucket.com%2Falbums%2Fu461%2Fwtucker91%2F20121124_190519.jpg&hash=3b959ff271b291ed56c644bdbc5e84e8eb1908ef)
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fi1069.photobucket.com%2Falbums%2Fu461%2Fwtucker91%2F20121124_191006.jpg&hash=37de2d25c48adc5b0d61fb37b79187f4d9425650)
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fi1069.photobucket.com%2Falbums%2Fu461%2Fwtucker91%2F20121124_191235.jpg&hash=57eea99be7e8ca44d2cff8cde44b31b6429f6eb4)
Post by: Number21 on November 24, 2012, 08:01:47 PM
Looking good! This will be running soon then eh  >:D
Post by: RevHappy on November 24, 2012, 08:30:03 PM
should be :)
Post by: BB on November 24, 2012, 08:57:10 PM
I love it, black here, black there, black everywhere!
Post by: RevHappy on November 25, 2012, 12:52:51 PM
ya could say all black
Post by: RevHappy on November 26, 2012, 05:15:14 PM
DAMN!!!!!! Big speed bump, stupid me didnt test fit everything before painting, put the 8v p/s on, new waterpump, 8v a/c bracket, 8v a/c pump, 8v alternator then went to fit the intake.................... uh ohhhh.
Intake manifold hits on the alternator. What do i do?
Post by: robh on November 26, 2012, 05:29:06 PM
Do you have a pic of clearance issue?
Is there a smaller alternator you can use?
I had same issue with VR6 motor and standard alternator which was too big, swapped for a smaller non VR6 one and just swapped pulleys over.
Post by: RevHappy on November 26, 2012, 06:47:38 PM
no will take a photo tomorrow night. i measured it with the intake manifold on and how far away the alt is from the bracket. 100mm off!!!!
Post by: Rex on December 05, 2012, 06:02:08 PM
any more progress?
Post by: RevHappy on December 06, 2012, 08:39:10 AM
Quote from: Rex on December 05, 2012, 06:02:08 PM
any more progress?
Put the motor in the hole on sunday and strained my back so have been off work since and cant do any work on it. So painful just standing there looking at all the work i could be doing with all this free time
Post by: RevHappy on December 11, 2012, 06:06:12 PM
Got back into it over the weekend. suspension, brakes, driveshafts, p/s, exhaust and shifter all done. but lost a brake line so does anyone have one hanging around they wanna sell? also with the spring thing that goes between the soft brake line and the hard brake line
Post by: Number21 on December 11, 2012, 06:50:16 PM
Did you sort the alternator problem?
Post by: RevHappy on December 12, 2012, 02:25:04 PM
Yea got a engineer to mod the bracket
Post by: RevHappy on December 15, 2012, 05:14:13 PM
Almost done chucking it all together and just found out that the bbm fuel rail i have needs a adapter to make it work with the fpr :( Means wont be going before xmas now
Post by: RevHappy on December 15, 2012, 05:23:08 PM
Need some advise from you tech wizz's
Will this work instead of using the oem fpr?
http://www.trademe.co.nz/motors/car-parts-accessories/performance/fuel-systems/auction-541688273.htm
Post by: watercooled on December 15, 2012, 08:10:13 PM
Quote from: gtimanik on December 15, 2012, 05:23:08 PM
No mate you need an adaptor to go in the fuel rail this kits have optional bits for sweet fa as far as you need,the main bit you  you need is not in this kit.
Be aware the hose supplied isn't rated for s#ht it cracks after a very short time ,if you value your car NEVER use it.
Post by: deedub on December 15, 2012, 09:45:03 PM
Hmmm looks to me like it would work. I see no reason why it wouldn't. If you're worried about the fuel hoses, just buy some quality stuff from BNT or somesuch, but the FPR itself should work. If I remember right the BBM rail is 8mm, it is designed to be used with an aftermarket FPR as VW ones sit in the fuel rail itself.
Hit up kiwi, his mate ... Arousn I think his vask name is - supplies aftermarket parts like FPRs and might be able to help.
Post by: RevHappy on December 15, 2012, 09:49:24 PM
I bid on the one on trade me. It should fit. The bum one needs a adapter what I don't have so I'm gonna use that one
Post by: watercooled on December 16, 2012, 09:33:56 AM
Quote from: gtimanik on December 15, 2012, 09:49:24 PM
The FPR is fine on its own,only said what I did cause I presumed your fuel rail took a standard fpr ,I made a fitting when I bought the same kit,I'am fussy when it comes to hose for obvious reasons
Post by: RevHappy on December 16, 2012, 09:50:26 AM
Quote from: watercooled on December 16, 2012, 09:33:56 AM
How did u make the adapter? Cause the fpr sits inside the adapter so it would have to be engineered to a mm
Post by: watercooled on December 16, 2012, 12:01:07 PM
Yea I did and the tolerances are close,but that was for a standard fuel rail, any half decent engineering place could make on for your aftermarket rail.
OK had a look on the BBM site did you buy the billet alloy one ? if so can't you take the end fitting off (rh side) and put a barbed hose tail on there to your fpr ? you need to set up to to 3.5 bar from memory ( you probably know that),also the instuctions are a bit dodgy atleast they were with mine best to Google it,cheers.
By the way keen to hear you get it running best part of all the hard work ;) ;) ;)
Post by: RevHappy on December 22, 2012, 02:16:32 PM
Alright fpr sorted. now just sensors and hoses left. need a bit of help. On the front of the motor there are two outputs for water hoses. the one on the head goes to water pump and radiator (correct?) where does the other one go?
Post by: BB on December 22, 2012, 06:49:38 PM
At the end of the head? Goes to the heater at the firewall.
Post by: RevHappy on December 22, 2012, 07:16:55 PM
nope. facing towards the radiator. above the oil filter housing
Post by: RevHappy on December 23, 2012, 08:42:41 PM
The one in the photo missing. What hose goes there and to where?
Sent from my GT-I9300T using Tapatalk 2
Post by: 00quattro00 on December 23, 2012, 08:51:01 PM
Thats the crank case breather, has a hose that attaches to it and goes to the airbox, also has some smaller hoses that go to the intake mani
Post by: RevHappy on December 23, 2012, 09:37:07 PM
Bigger. You don't have one ya wanna sell basil? Also do u know what the outlet on the end of the intake manifold is? On the lower section of the manifold and on the passengers end of it
Post by: RevHappy on December 28, 2012, 12:02:42 PM
Seeing as noone can help me with this problem. im just going to make a oil catch can setup.
Does anyone have a breather off of a AEG MK4 motor?
looks like this
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fwww.bahnbrenner.com%2Fvw_audi%2Fproducts%2Fproduct_images%2Fphpof6wIu.main_thumb.jpg&hash=e23c91c91d329b8a6340b0d3abd76c549b14f4b1)
Post by: RevHappy on January 03, 2013, 10:10:58 AM
Can someone, anyone help me with parts please. All i need is a front right brake line
Post by: AndyGti on January 03, 2013, 12:02:45 PM
hey man checked my stock and none i can find. you can get them from partmaster or auto one?!
Post by: RevHappy on January 03, 2013, 11:52:00 PM
oh sweet will go there tomorrow
Title: Re: Re: Mk2 Digi2 9a
Post by: RevHappy on January 04, 2013, 04:30:10 PM
Quote from: AndyGti on January 03, 2013, 12:02:45 PM
Hey mate thanks for the advise got one today cheap as chips
Post by: AndyGti on January 04, 2013, 05:54:06 PM
no probs!
Post by: RevHappy on January 13, 2013, 08:55:07 PM
Tried to start the car today. Started leaking fuel. Also have a small leak from the coolant flange on the side of the motor. I'm after a passat16v metal coolant flange. Both my mk2 plastic ones leak. But she's almost done!
Post by: BB on January 13, 2013, 09:02:24 PM
Mine is running sweet, looking forward to hearing that yours goes!
Post by: RevHappy on January 13, 2013, 09:07:31 PM
Do u have a coolant flange? I tried another o ring but no luck. The mk2 one I have looks very oval
Post by: BB on January 13, 2013, 10:29:01 PM
Just ring Qualitat they will send you a new one in a day or two cheap as chips.
Post by: RevHappy on January 13, 2013, 11:14:54 PM
Hey just want to do some double checking. Can someone with a digi 2 Mk2 tell me what colour the wires are that go to the fuel rail, knock sensors, isv. Also how many knock sensors does a digi 2 mk2 have? I can only remember one. But there are two on my 9a
Post by: RevHappy on January 15, 2013, 10:22:16 PM
Ok. im in real need for someones help here! The golf is playing with me now. Went out to the garage today to give it a go at cranking it over. battery is flat so put a jump pack on. with the jump pack on the + and - terminals of the battery the interior light comes on and the interior fan switchs on and stays on ( it didnt used to do this ) but it wont crank over :(. With the -ve jumper lead on the intake manifold bolt and +ve on the battery it will crank the motor as it should but wont start.....? Why?
Once i got the motor cranking it wouldnt fire up.............and the isv isnt buzzing away like it usually does. I pulled the fuel rail out to check the injectors because i am skeptical about the plug that i have used (blk/yel and brwn/yel) and  nothing. definitely fuel pressure as the gauge is reading 6bar. So i hooked up a hot wire to see if the injectors actually work or not and they open and close as they should on the hot wire. ARGHHHH
Can someone please please please help me. Im sure someone has been there done that before.
Will
Post by: BB on January 16, 2013, 08:41:47 AM
Hi Will, I don't have a mk2 digi to check anymore sorry tho later I will look at my Bentley manual for the wire colours to the Rail.
I am sure tho that if you have two plugs that could fit you should just try the both of them separately?
Also just charge your battery and hope that cures the odd electrics. Make sure all your earths are clean and good as this is the usual reason things go odd as they try to find paths to earth.
Then with the battery good check for spark if yes then spray engine start, if it runs then simply figure out how to power the fuel rail (must be one of the plug surely?) and you should be away!
Post by: RevHappy on January 16, 2013, 10:24:34 AM
Tried to charge the battery all yesterday but I think it's buggered aol will need a new 1. Had limited tools last night (10mm spanner and a tiny pair of vice grips) so will take more home and check spark. The coil is sparking cause that got me really good
Post by: BB on January 16, 2013, 05:27:46 PM
You just have to not stress and do the basics, check everything.
Post by: RevHappy on January 16, 2013, 09:08:39 PM
Yea cheers for your help jem. Can u tell me why when I turn the key onto power the fuel rail is giving my test light a full glow? Not pulsing as I thought it would. Doesn't change when cranking. Got the motor to burst into life briefly so that made me happy. Will get it running Friday.
Post by: deedub on January 16, 2013, 09:56:27 PM
Quote from: gtimanik on January 16, 2013, 09:08:39 PM
Great to hear you're nearly there!
I'd check the distributor hall sender and associated wiring, on digis it is the only signal to the ecu that the engine is turning over.
Post by: RevHappy on January 16, 2013, 10:50:21 PM
so i shouldnt be getting full power on my test light?
Post by: deedub on January 17, 2013, 12:58:54 AM
Full power on what? Should be constant 12V on the live to the fuel rail, as they have pulsed earths. But if the ECU isn't getting a signal from the hall sender, it doesn't tell the injectors to squirt. So worth a look, along with the fuel rail wiring.
Post by: RevHappy on January 17, 2013, 12:51:25 PM
Awesome. Ordered a new coolant flange. And just read up about testing wiring for hall sender and injector wires. Getting exciting now. Why would the isv not be buzzing though as it usually would?
Post by: Thomas on January 17, 2013, 01:04:32 PM
Quote from: gtimanik on January 17, 2013, 12:51:25 PM
I'm running megasquirt so possibly not relevant but thought i would post anyway in case it helps. I found that the isv in my car did nothing while my hall sender was bung. The moment i replaced the hall sender the isv buzzed away if i turned the engine over (or for that matter turned the dizzy by hand) not sure if yours just did it while the ignition power was on or when cranking though.
Post by: RevHappy on January 17, 2013, 03:19:48 PM
Mine used to buZz while the key was on. Will check the hall sender tomorrow night.
Post by: BB on January 17, 2013, 04:28:20 PM
It is true that the digi has a pulsed earth (well Im not going to doubt Deedub ;)) but unlike most EFI the early digi does not pulse each individual injector, they all spray at the same time like a CIS  K-jet system.
Also the idle valves are a solenoid, they should click open with power and click closed with the power off, they should not buzz. They buzz when they are crapping out as far as I know.
On the mk2 digis the ISV is as it says, an Idle Stabilization Valve. They are triggered not by the idle switch on the throttle body but by low revs. They open a air way that bypasses the closed butterfly and gets the revs back up, Ie they stop it stalling.
On the later mk3 gti ABFs the solenoid is a Idle Valve. On lift off the butterfly closes completely and hits the idle switch which opens the IV and allows air past the butterfly allowing the car to idle.
If you ask JohnP he will tell you how you can test the Hall....................cause I always forget tho I think its just put power to it and a earth and read the middle prong with a multimeterwhen turning it by hand, obviously with it removed from the car.
Post by: 00quattro00 on January 17, 2013, 06:30:29 PM
If he has spark then there is nothing wrong with the hall sensor
Sent from my GT-N7100
Post by: BB on January 17, 2013, 07:55:46 PM
True.
Make sure you have all your earth on especially the one from the rocker cover to the coil or you will blow the ecu and the injectors will jam full on :P
Post by: deedub on January 17, 2013, 08:00:53 PM
Quote from: 00quattro00 on January 17, 2013, 06:30:29 PM
Yes sorry missed the part about getting spark. Guess fuel rail wiring, should be easy enough as it's only two wires. No fuel smell at all?
Post by: RevHappy on January 17, 2013, 11:04:21 PM
Got it all sorted out last night. That is how I got it started. The injector wires had the polarity backwards so when switched the injectors were going full tit on start up. Definitely got spark. Does this mean the hall sender is ok Quattro? Am devoting a full afternoon and night to it tomorrow. Reason why I didn't get it running and leave it running was I thought the injectors would make it rev until it blew and the earth I had was smoking. Got one from the head to the coil. Putting 2 more proper earth straps on from a mate that works a FH so pretty sure they will be beefy
Post by: deedub on January 18, 2013, 12:57:10 AM
Quote from: gtimanik on January 17, 2013, 11:04:21 PM
Yup sounds like your hall sender is fine. Make sure your gearbox earth is good! If the one at the head is smoking while cranking I would check the big gearbox one as well.
Be careful if you think your injectors are on full, apart from filling the sump with fuel you can also hydraulic the motor too if you crank it for too long.
Post by: johnp on January 18, 2013, 08:26:28 AM
My guess is you do not have a proper battery to body to motor earth. The big butty cable.
You may have earthed thru the ECU when cranking and fooked the ECU, hence the injectors are on full tit.
The polarity to the injectors does not really matter as they are not sequentially driven and are just coils.
Post by: BB on January 18, 2013, 09:23:29 AM
I'm worried he has fried his ecu as well....everybody does :P
I have had earths all bolted tight etc but not connecting.
Remove all the earths and sand everything clean.
Then try another Digi ecu.
Post by: RevHappy on January 18, 2013, 12:42:06 PM
Earth strap is coming tonight as I want find the one on the gearbox. Will try tonight
Post by: BB on January 18, 2013, 04:52:29 PM
 Pull the plugs out and then fit them to the leads and lay the plugs so they can earth to the head.
Then crank it.
If it sprays fuel out the plug holes (plugs can ignite this for a bit of action!) you have a blown ecu.
Post by: RevHappy on January 18, 2013, 08:43:50 PM
Quote from: BB on January 18, 2013, 04:52:29 PM
Then crank it.
How? i dont understand how it shouldnt spray fuel out the plug holes?
Post by: deedub on January 18, 2013, 09:01:27 PM
Mmmm if your earth strap was smoking it does seem fairly likely that your ecu is toast.
As has been stated before, if your earths aren't totally sorted the starter earths through the ECU and burns out part of the ECU board, which causes the injectors to get stuck on full cycle. Seems this happens quite a lot when clutches get changed and earths get missed out.
I think I have an ECU somewhere you can try if it turns out it has been cooked.
You can do what Jem suggests just to see if the injectors are on going full tit, it's best to take the plugs out so it's easy to tell that there's heaps of fuel going in and also will prevent the motor killing itself by trying to compress all the fuel that has been dumped in the cylinders. Sounds a bit dangerous though!  And you have nice paint on the motor  :-[  Or you could unplug the injector plug and get an auto scope between the fuel rail supply wires to see what duty cycle the injectors are on if you have a mate who is a sparky. A friend of mine had one and it was very handy for this kind of troubleshooting.
Post by: RevHappy on January 18, 2013, 09:35:30 PM
Quote from: deedub on January 18, 2013, 09:01:27 PM
If i could borrow another ecu that would be mint. Will chuck some more earths on tomorrow. Also tried to get into contact with Andrews mate with the mk2 parts car. But hes not too sure if it will be the same so also put a ad on the trading post
Post by: deedub on January 18, 2013, 09:41:48 PM
Quote from: gtimanik on January 18, 2013, 09:35:30 PM
You mean Craig? Pretty sure his parts car is an '88 or '89 so should be sweet as. I definitely have a working one somewhere, but Andrew will have to try to find it.
Post by: RevHappy on January 19, 2013, 12:56:33 AM
Yea. He was real good about the other parts. Trying to get the ecu for tomorrow
Post by: RevHappy on January 19, 2013, 10:40:15 AM
How much do u want for ur ecu?
Post by: Number21 on January 19, 2013, 02:38:17 PM
Sorted, if Craigs ECU doesn't work I'll track down Deedubs one, I've got Craigs at home now. If you aren't in a hurry I can drop it at your place tomorrow or maybe tonight.
Post by: BB on January 19, 2013, 04:55:47 PM
Its not dangerous. its just if you cant find a place to earth the plug away from the fuel coming out the spark holes it can ignite with a quick flash, it won't hurt anything.
The reason is if you want to crank a car with the plugs out you do really need to earth the leads so the spark can escape or you can damage more stuff.
You could do this by adding a test wire from the leads to the block rather than the sparking plugs but hey I enjoy making flames >:D
People fry the ECUs when they do the clutch as you have to move the engine so much to swivel and remove the gearbox you need to undo the earth strap to coil and they forget to put it back on.
Its a real drag.
Do as I say remove all the earth leads and sand clean and reattach. There is one from battery to the battery tray then down to gearbox.
Then there is the small rocker to coil.
This is enough if they are all good, but fitting more can't hurt.
I have a earthing lead set that came off a MK3 gti I am going to fit to my mk2 abf......just cause I have it and its a nice bit of kit.
Post by: RevHappy on January 19, 2013, 05:57:53 PM
Sweet. I fitted a new batter to body to earth lead. New rocker to scuttle. And new box to chassis.
Post by: RevHappy on January 19, 2013, 07:43:16 PM
Thanks to Andrew, Craig, and Dave I got the engine started and running. 3 ecus later. Only problem is it won't hold a idle. Is that cause of the signal from the temp sensor isn't good for the ecu? Or isv not working? Or wrong ecu? The ecu numbers match except for the last two letters. Does that matter? Going to try the ecu chip in the working ecu to see if that will work.
Post by: BB on January 19, 2013, 08:26:39 PM
Don't much around with the ecu yet.
And the rocker earth should go to one of the coil bolts not just the scuttle I think is best in case the coil is not attached to the scuttle well.
If it starts and revs and drives ok then your idle will be because the idle switch is not working or the ISV is dirty and part open or you have the timing a bit out or something I doubt its the actual ecu.
But good going.
Post by: RevHappy on January 19, 2013, 09:02:45 PM
The rocker to coil earth has always been on there. I just added another for security onto the rocker. It starts and revs fine but the rev is ambit delayed. I'll upload a vid soonish so ya can see it. I think it's the isv tbh. So even though the letters on the ecu don't match it should be ok? The new one says TAN where as the old one didn't
Post by: deedub on January 20, 2013, 04:35:36 AM
That's craig's ecu? It shouldn't matter. Yo could try my one as well anyway, but I am pretty sure they will be near identical. I think the ISV setup on a digi 9A is a little bit tricky, might pay to have a read through the US forums about how people have got them idling well.
You mention that you fitted an earth from box to chassis - from memory there should be a box to battery one? That might be a good one to have just in case, to give the starter motor a really easy earth path.
Good work that you have it running!  8) 8)
Post by: deedub on January 20, 2013, 05:02:15 AM
PS just saw your video on FB, sounds like your timing might be off as well. Did you change the cambelt? Or had I just put a new one on it when I sold it to you? I forget now...
http://www.edition38.com/forums/index.php?showtopic=174702
Post by: RevHappy on January 20, 2013, 11:58:50 AM
I'm pretty sure u chucked one on as it looks new
Post by: RevHappy on January 21, 2013, 09:11:17 PM
Starts runs IDLES! But tachometer isn't registering could be because no alt
Post by: 00quattro00 on January 21, 2013, 09:26:57 PM
Quote from: gtimanik on January 21, 2013, 09:11:17 PM
Tacho is taken off neg side of coil
Post by: RevHappy on January 21, 2013, 10:19:25 PM
Quote from: 00quattro00 on January 21, 2013, 09:26:57 PM
Damn. There is a spare terminal on the coil. thats probably it. will have to find the wire to go to it. any ideas on colour?
Post by: Number21 on January 21, 2013, 11:38:45 PM
Quote from: gtimanik on January 21, 2013, 10:19:25 PM
I had a look at a wiring diagram for a post 1987 Mk2 and it showed red/black. That is just from the haynes manual.
Post by: deedub on January 21, 2013, 11:43:35 PM
Quote from: Number21 on January 21, 2013, 11:38:45 PM
It's black/red on my car, pretty sure.
Good work Will! What was the culprit?
Post by: BB on January 22, 2013, 10:45:39 AM
So cool :)
One of the last things I need to do is attach the tacho on my car and was wondering what wire.
So the black red wire goes on the negative side of the coil?
Post by: RevHappy on January 22, 2013, 12:41:50 PM
Quote from: BB on January 22, 2013, 10:45:39 AM
So cool :)
It would seem so. Will do that tonight
Post by: RevHappy on January 22, 2013, 07:02:44 PM
Mine was plugged in just on a angle. So only half plugged in
Post by: deedub on January 22, 2013, 08:09:43 PM
Driven it yet ?
Post by: RevHappy on January 22, 2013, 08:47:42 PM
That's planned for this weekend. Gotta shoe horn it between all the other things to-do
Post by: RevHappy on January 22, 2013, 09:14:39 PM
But I'm pretty excited. Any one know what these two plugs are for?
Post by: BB on January 25, 2013, 08:26:10 AM
AC I think?
I think lots of golfs have them just sitting there like that.
Post by: RevHappy on January 26, 2013, 10:56:55 PM
Drove it today
Post by: deedub on January 27, 2013, 01:14:19 AM
And?
Post by: RevHappy on January 27, 2013, 08:20:42 PM
Love it. Much better torque
Post by: deedub on January 28, 2013, 04:32:15 PM
Quote from: gtimanik on January 27, 2013, 08:20:42 PM
8) 8) good work bruv!
Post by: Benni.B on January 30, 2013, 12:21:40 PM
So whei wanna come see. Feel the difference between a16v and my8v.
Post by: RevHappy on January 30, 2013, 06:12:08 PM
Soon mate lol. Will definitely give ya a ride. but need to sort out legalness and a few wee things
Post by: Benni.B on January 30, 2013, 06:31:32 PM
Sweet. and what did the grille and the strut mount come off. u not running them on ur mk2
Post by: RevHappy on January 31, 2013, 07:10:33 AM
i just dont like the grille as much as i thought i would. and the strut brace hits on the 16v manifold so no use to me
Post by: BB on January 31, 2013, 08:14:06 AM
A strut brace is a waste of time on a mk2 unless you have tyres so wide a sticky and are holding a few Gs in a corner.
Post by: Benni.B on January 31, 2013, 12:29:37 PM
Quote from: gtimanik on January 31, 2013, 07:10:33 AM
ahh i see.
Post by: RevHappy on January 31, 2013, 07:17:32 PM
Quote from: BB on January 31, 2013, 08:14:06 AM
Yea but it is a nice piece of bling
Post by: nacnud on February 01, 2013, 11:46:36 AM
lets see some photos!
Post by: BB on February 02, 2013, 10:05:08 AM
Quote from: gtimanik on January 31, 2013, 07:17:32 PM
Or a pain in the ass as it gets in the way and a waste of money too.
But that won't stop any of you young lads fitting them.
They are needed in the mk1, but even then its the lower brace that does the most.
Post by: RevHappy on February 02, 2013, 04:45:51 PM
Did a bit more on the car today. got it up to temp. got the fan spinning and left it idling for a while. my old 8v couldnt do that! need to get a new battery and then take it to work for more tlc. Can anyone tell me why the brake pedal wont come all the way out? it wont come back to the stopper to turn the brake lights off. if i pull really hard it wont budge
Post by: BB on February 02, 2013, 04:54:25 PM
Ha ha that weird I thought my brake pedal had gone funny as well as my brake lights were on all the time I had the battery connected!
It is the actual brake light switch it can be adjusted and you will have bumped it whilst mucking around under there.
You grab the switch pin and pull it down to where it touches the pedal.
Post by: RevHappy on February 02, 2013, 05:15:30 PM
Quote from: BB on February 02, 2013, 04:54:25 PM
PHEWW!
Post by: RevHappy on February 02, 2013, 05:43:30 PM
Couple of shots showing my abysmal work conditions. But all in all it just needs a battery and the throttle cable sorted and I'll be back to dailying
Post by: watercooled on February 16, 2013, 01:05:15 AM
Work good on 2 of our mk2's,not sure why you say that Jem?,the mk2 body isn't very rigid.
Keep your's Will with the right suspention setup they do work.
Post by: deedub on February 16, 2013, 05:23:58 AM
Quote from: watercooled on February 16, 2013, 01:05:15 AM
Only issue is it doesn't fit over the mani of a 16v.
Post by: ranton-inc on February 16, 2013, 09:03:58 AM
You coulf always do a two peicr strut brace that starts on the tower and then goes back and bolts towards the middle of the firewall they are pretty effective too.
Sent from my GT-I9300 using Tapatalk 2
Post by: RevHappy on February 16, 2013, 09:11:03 AM
I like the one I saw on a mk2 jetta.  Think it had vw motorsport cnc'd onto the top of it. Was over a 9a. Any way the nor I have is up for grabs in the trading post
Post by: BB on February 16, 2013, 11:28:44 AM
If you say so. I'm not one to argue.
Was the brake light switch what I said Wil?
Nice lookin stance.
Post by: RevHappy on February 16, 2013, 11:47:08 AM
Quote from: BB on February 16, 2013, 11:28:44 AM
Nice lookin stance.
I cant figure it out. im working on it now. doesnt seem to move.
Post by: RevHappy on February 16, 2013, 11:48:58 AM
Quote from: gtimanik on February 16, 2013, 11:47:08 AM
DUHHHH after writing that post. Walked out there. pulled on the whiteish rod into the brake switch and out it came!
Post by: BB on February 16, 2013, 03:46:17 PM
Post by: watercooled on February 16, 2013, 04:38:23 PM
Quote from: deedub on February 16, 2013, 05:23:58 AM
True mate forgot about the 16v,the brace I had fitted with the crappy GX motor and stuffed mounts never came close to touching the motor,did the 3a conversion and it fouled real bad on the TB ,a quick bend up on the alloy centre section and all was good and it still cleared the bonnet.
Will, my boy has a front offset brace that I had on my old 4 door that type would clear your manifold.
Post by: RevHappy on February 17, 2013, 01:41:10 PM
I am bidding on a 16v lip on tm for this but just noticed that it is pick up only. Does someone feel helpful enough to pick it up for me and send down to chch. I will pay for the item before it is picked up. And u will also be paid for your time, gas, and of course shipping
Post by: KARTS on February 17, 2013, 04:02:35 PM
I could do that for you and send it through our freight guys at work if you want. When and where does it need to be picked up (if you win)??
Post by: RevHappy on February 17, 2013, 04:25:04 PM
Quote from: KARTS on February 17, 2013, 04:02:35 PM
That would be awesome. I don't know the location but it says Auckland city on their profile. I have also asked a question where pick up would be
Post by: RevHappy on February 17, 2013, 07:05:40 PM
Located in greenlane
Post by: KARTS on February 17, 2013, 07:14:06 PM
Yeah I can manage that. Pm me if you win and I'll sort it out.
Post by: RevHappy on February 28, 2013, 08:38:13 PM
Quote from: KARTS on February 17, 2013, 07:14:06 PM
your inbox is full mate. That lip is ready for pick up
Post by: KARTS on February 28, 2013, 08:49:58 PM
All good man, flick me a text. 021611633
Post by: RevHappy on February 28, 2013, 09:36:05 PM
Took some photos away from my garage
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fimg.tapatalk.com%2Fd%2F13%2F02%2F28%2Funujynu7.jpg&hash=9ab8dde623e3cc025c9ee3433feb5dc6850da1eb)
(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Fimg.tapatalk.com%2Fd%2F13%2F02%2F28%2Fumutaze2.jpg&hash=2055da4913a97ea7970acd0ebe0b65a02c0f4e38)
Post by: BB on March 01, 2013, 04:44:43 PM
Looks beasty.
Post by: RevHappy on March 01, 2013, 07:09:40 PM
Quote from: BB on March 01, 2013, 04:44:43 PM
Looks beasty.
Cant get over how much difference a good tune does. The timing made it soo much better. And the 2 1/4 exhaust breaths so well
Post by: BB on March 01, 2013, 07:12:58 PM
Correct ignition timing is everything.
Post by: RevHappy on March 01, 2013, 07:14:48 PM
Quote from: BB on March 01, 2013, 07:12:58 PM
Absolutely agree. Bit of piggy bait at the moment with the sports exhaust and steelies but who cares. Its worth it cause its so much fun
Post by: BB on March 01, 2013, 07:17:45 PM
If its legal and you have a license and your not pissed or driving wrong I don't mind being pulled by the fuzz, They check everything and are nice to deal with if everything checks out.
Post by: RevHappy on March 01, 2013, 07:19:08 PM
Only problem (and dare i start a discussion) is the motor not being cert'ed but no normal cop can recognize that
Post by: BB on March 01, 2013, 07:21:26 PM
All they want is the stickers on the screen and your license.
I thought you didn't need a cert for fitting a 1.8 to 2l engine non turbo-ed?\
How knob end if you do ::)
Post by: deedub on March 01, 2013, 07:45:01 PM
Quote from: BB on March 01, 2013, 07:21:26 PM
I think it's something like a 20% change in power and you're supposed to get a cert. Not sure though, because I can't see it ever being a problem.
Post by: BB on March 01, 2013, 08:34:52 PM
I'm not getting one for my ABF.
Its such a toss off anyway certing when its the driver and or any mechanical thing like leaving a wheel nut loose which can happen any time that will cause an issue.
They just take your money for crap.
Post by: choppy16v on March 02, 2013, 09:29:58 AM
just plead ignorance and state you got the car this way and engine is factory as far as yo know.
and the steelies are not widened but were built this wide.
i got cert but only to rectify green sticker,but is for works burger-seats,susp,engine,exhaust,etc
it feels like a protection against dick head cops but pricey at $650
Post by: BB on March 02, 2013, 10:45:32 AM
It is just protection against a dick head law.
Post by: RevHappy on May 23, 2013, 12:30:08 PM
Alrighty car has been going good up until saturday. Starts to miss fire on idle and cruising once up to about 85-90? but not on accel. There was also water in the oil catch can. Im pretty confident its the head gasket but after a little reassurance before I rip it off. If I do then a p+p and abf cams will get thrown in too
Post by: deedub on May 23, 2013, 03:24:08 PM
How much water in the oil catch can?
I wouldn't jump to the conclusion of headgasket. It's just getting colder and wetter in chch, my kombi would get water in the catch can and even foamy oil - and it's aircooled! It was to do with the engine not running the best rather than headgasket. If you have oil in the water or bubbles coming up through the header tank, or coolant hoses pressurising, then I'd be more certain it is a headgasket.
Post by: Number21 on May 23, 2013, 03:28:39 PM
Yeah, the mayo gets on the cap of every car I've owned as soon as the weather gets a bit cold and wet, burns off after a bit of a run.
Do you get the bubbling in the coolant?
Post by: RevHappy on May 23, 2013, 04:42:14 PM
Quote from: Number21 on May 23, 2013, 03:28:39 PM
Havnt noticed any bubbling. But it does get a miss when warmed up.
Was about 150-200mls of water in catch can
Post by: RevHappy on May 23, 2013, 04:42:36 PM
But the water wasnt that oily rho
Post by: deedub on May 23, 2013, 05:02:49 PM
That's a lot of water. If it was a big head gasket failure I would have thought the hoses would be well blown up. If it's just a water to oil failure, it won't be what's causing the miss anyway.
Post by: RevHappy on May 23, 2013, 05:31:03 PM
Yea thats what I thought. Could it be moisture? Catch can sits low in bay with no inner guard trims and has the filter on the top
Post by: Benni.B on May 23, 2013, 05:52:25 PM
I get frick loads of moisture in my mk2 will. but not sure id that could be related to that much water being in in the catch can. Suppose it has to go somewhere have you modded the head? just curious.
Post by: RevHappy on May 23, 2013, 05:58:23 PM
Nope standard 9a I think. Deedub is that right?
Post by: choppy16v on May 23, 2013, 06:12:25 PM
factory oil cooler failure? i've had to replace them before.take it off and look for corrosion.
Post by: RevHappy on May 23, 2013, 07:55:21 PM
Quote from: choppy16v on May 23, 2013, 06:12:25 PM
oil cooler? i dont believe i have one. Unless its mounted to block
Post by: deedub on May 23, 2013, 09:20:19 PM
Quote from: gtimanik on May 23, 2013, 07:55:21 PM
They have an oil cooler standard. Near the oil filter.
The motor was standard, never been split, ran like a champ. 140kms I think.
I guess if water is getting flicked up onto the catch can breather, that could be where the water is coming from.
200mls, you'd notice that as a drop in the coolant level. Fill it up and keep an eye on it. I'm pretty confident you don't have a headgasket issue though.
Post by: RevHappy on May 23, 2013, 10:18:43 PM
Quote from: deedub on May 23, 2013, 09:20:19 PM
So coil leads or dizi then? Will chuck another coil on this weekend and see if that fixs the miss
Post by: BB on May 26, 2013, 11:29:57 AM
Leads are far more likely to cause a miss.
Post by: RevHappy on May 27, 2013, 06:37:01 PM
Some how the 9a fixed it self. No more water in catch can with a full coolant bottle. No more miss fire. Will do a service on it this weekend.
Post by: BB on May 29, 2013, 02:42:00 PM
I love cars that fix themselves.
Post by: RevHappy on June 07, 2013, 08:45:22 PM
Is there any oem engine mount upgrade to the 8v mk2 ones? Mine feel rather sloppy with the new motor
Post by: ranton-inc on June 07, 2013, 08:51:09 PM
Quote from: RevHappy on June 07, 2013, 08:45:22 PM
You can do the solid aluminum front mount and thr g60 solid rubber rear mount
Post by: RevHappy on June 07, 2013, 09:08:32 PM
Cheers mate will look into it
Post by: RevHappy on February 27, 2014, 06:05:56 PM
Alright. Bit of a update. Got some abf cams from ranton. Still havnt chucked them in. Finally bought myself a daily. And got my golf into my workshop. Car has been stripped for 2 weeks. Got alot of panel beating done. Front guards, doors, tail door. And roof. All glass removed. And colour decided. Got rear guards, front valence and bonnet left. Then primer, paint and reassemble. Also got my coilovers delivered yesterday. Cant wait to chuck them in and the cams. So stoked and excited to get it finished and show it off!
Post by: RevHappy on February 27, 2014, 06:06:50 PM
Thats before the glass was removed
Post by: whitemk2 on February 28, 2014, 01:20:17 PM
Quote from: RevHappy on February 27, 2014, 06:06:50 PM
Hi, what are the specs on those wheels if you dont mind?
cheers
Post by: RevHappy on February 28, 2014, 03:22:50 PM
15x8 widened steelies. 195 / 50 / 15 tyres
Post by: RevHappy on March 26, 2014, 08:34:48 PM
Update. all dwnts fixed uljust need final priming then rub down. Tonights job. Make patches for 3rd wiper hole and rust in windscreen frame
Post by: RevHappy on March 26, 2014, 08:36:38 PM
templates made from a old street fords mag page. Welding tomorrow
Post by: RevHappy on April 08, 2014, 11:14:58 PM
Alrighty. After a few bits and bobs. Need a digi 2 8v non gti cluster, fuel pressure regulator, and airbox with airflow meter.
I cant figure out how to post a new thread on tapatalk so I posted here
Cheers guys
Post by: wsnownz on April 09, 2014, 08:38:48 PM
Awesome progress man.
Post by: cpncrash on April 09, 2014, 08:44:57 PM
I have a digi air flow meter, no air box tho I don't think
Post by: RevHappy on April 09, 2014, 09:40:36 PM
Quote from: captncrash on April 09, 2014, 08:44:57 PM
Too easy. Just need the air flow meter as mine has been tinkered with but cant remember how to tinker back.
How much u after?
Post by: RevHappy on April 09, 2014, 09:41:19 PM
Quote from: wsnownz on April 09, 2014, 08:38:48 PM
Cheers mate. hopefully colour painted this week. Then all black needs doing
Post by: cpncrash on April 09, 2014, 09:53:23 PM
PM sent, might be able to help with the other bits too :)
Post by: RevHappy on April 11, 2014, 10:23:18 PM
Ohhhh lala what do we have here?
Post by: RevHappy on April 11, 2014, 10:25:02 PM
Does anyone know of window tint that is sold to the public or automotive tradie that is of great quality and doesnt fade at all?
Post by: RevHappy on April 12, 2014, 06:52:23 PM
Got the car all prepped last night and painted this morning. Looking very lush in the new hue
Title: Re: Mk2 Digi2 9a
Post by: RevHappy on April 13, 2014, 04:31:00 PM
More progress. Guards on. Lights on. Just need to hang the doors and bonnet to do final guard gapping
Post by: KARTS on April 14, 2014, 07:40:49 PM
Nice! Is that Oak Green or a custom colour?
Post by: RevHappy on April 14, 2014, 09:11:21 PM
Quote from: KARTS on April 14, 2014, 07:40:49 PM
Cactus green. (Mk3 colour and b5 s4) not common at all
Title: Re: Re: Re: Mk2 Digi2 9a
Post by: RevHappy on April 14, 2014, 09:12:30 PM
The flip in the light is the best part. Once assembled will get some good photos
Post by: M M on April 15, 2014, 07:48:30 AM
Nice color choice. Looking forward to see it all put together.
Post by: watercooled on April 23, 2014, 09:24:51 PM
Well done Will ,looking great,miss my mk2 :(
Post by: RevHappy on April 23, 2014, 09:35:12 PM
Some more progress. All panels on now. Just waiting on chrome pieces so I can shut the doors and windows tinted so they can go in. And bumpers and flares to be finished
Exciting
Post by: RevHappy on April 23, 2014, 09:35:55 PM
Quote from: watercooled on April 23, 2014, 09:24:51 PM
Cheers mate. Its looking very dusty lol. Is a waiting game at the moment
Post by: Number21 on April 24, 2014, 09:02:53 AM
Nice!
Of course I'm biased towards green  :P
Post by: RevHappy on May 03, 2014, 06:17:10 PM
Does anyone have a golf italic badge they will part with In good condition. Mine is too far gone
Post by: Mitch on May 03, 2014, 10:45:24 PM
I lick your car pwease ?
Post by: RevHappy on May 03, 2014, 11:24:56 PM
Quote from: Mitch on May 03, 2014, 10:45:24 PM
Yea why not. Needs a clean.
Post by: RevHappy on May 17, 2014, 04:05:01 PM
New update woop. See dave(deedub) told ya it would get done, one day lol
Post by: RevHappy on May 17, 2014, 04:05:30 PM
Title: Mk2 Digi2 9a
Post by: Poonmobile on May 17, 2014, 04:18:41 PM
What are the wheel and tyre specs again?
Post by: RevHappy on May 17, 2014, 04:27:42 PM
Quote from: Poonmobile on May 17, 2014, 04:18:41 PM
Volk CV Pro unknown offset.
16X7  16X8
20mm spacer on rear and 25mm on front.
195/45/16 all round
They are the next project
Post by: VW'n on May 17, 2014, 08:31:43 PM
Nice, All that hard work's paying off!
Title: Mk2 Digi2 9a
Post by: Poonmobile on May 17, 2014, 11:13:39 PM
Quote from: RevHappy on May 17, 2014, 04:27:42 PM
16X7  16X8
195/45/16 all round
You are still running 4x100 set up right?  Staggered set is nice, did they could the brakes before you spaced?
Post by: RevHappy on May 17, 2014, 11:52:56 PM
Quote from: Poonmobile on May 17, 2014, 11:13:39 PM
They use volk internal wheel nuts and as everyone here knows vws have wheel bolts. And couldnt track down any volk wheel bolts so need adapters
Post by: Mitch on May 19, 2014, 12:09:02 AM
Dat colour though
Post by: Number21 on May 19, 2014, 10:04:32 AM
Looks great! The 16v lip is remarkably straight too!
Post by: RevHappy on May 20, 2014, 10:25:28 PM
Wee update. Ride height change. And off to wheel alignment this week
Post by: RevHappy on May 20, 2014, 10:28:16 PM
Post by: RevHappy on June 04, 2014, 06:35:59 PM
update. Car was running mint all this time then last saturday I left pick a part and gave it a bootfull and it went then died. Found out the rotor had blowen apart and taken the hall sender with it. Me and dad patched it in thd pickapart workshop using a polo hall sender and rotor as he didnt have a mk2 there. Now I have problem after problem
Post by: ranton-inc on June 04, 2014, 11:21:55 PM
Quote from: RevHappy on June 04, 2014, 06:35:59 PM
ABF with EFI time..
Post by: RevHappy on June 05, 2014, 07:04:19 AM
Quote from: digifart on June 04, 2014, 11:21:55 PM
ABF with EFI time..
Na m/s. There is a guy in chch that tunes them. one of only a few
Post by: RevHappy on June 05, 2014, 08:21:17 AM
My battery is reading 13v when idling but battery is flat every morning. Would it be the alternator? Or do they only charge 13v? Battery is newish and no drains when the car is off
Title: Re: Re: Re: Re: Mk2 Digi2 9a
Post by: RevHappy on June 05, 2014, 08:40:19 AM
Quote from: RevHappy on June 05, 2014, 08:21:17 AM
Also when the car is hot and I turn it off to get gas or to nip into a shop then go  to restart it I get maybe one or two cranks, very slow cranks like the starter is having trouble to start then sometimes it will burst into life. Other times will just kill the battery and will need a jump. Thinking bad earth, too weaker battery or starter not upto task. Am using the 1.8 8v starter. Have inquired about a 1040cca battery to try and muscle away the issue. But scared of buying a super expensive battery and killing that too.
Post by: GolfJon on June 05, 2014, 01:37:30 PM
13V would be about right. If you are sure the battery is ok, then its probably the alternator- sounds like it is not charging the battery enough.
Post by: RevHappy on June 05, 2014, 02:15:33 PM
Quote from: GolfJon on June 05, 2014, 01:37:30 PM
So get the alternator rebrushed? Have access to a mk3 one.
Post by: GolfJon on June 05, 2014, 09:12:01 PM
That might be enough, depends how far gone it is. Personally I would just replace the alt.
Post by: RevHappy on August 08, 2014, 11:53:33 PM
Alrighty. Has anybody got a mk2 box lying around? Or better yet a 02a from a mk3 gti? Rather interested in the hydro clutch idea
Post by: ranton-inc on August 09, 2014, 05:09:41 PM
Quote from: RevHappy on August 08, 2014, 11:53:33 PM
I have a mk3 16v box
Post by: RevHappy on August 09, 2014, 05:43:50 PM
Quote from: ranton-inc on August 09, 2014, 05:09:41 PM
And all appropriate hardware? Thinking of cutting and welding the pedal, cause finding a corrado or b3 passat one is too hard.
Post by: ranton-inc on August 09, 2014, 06:13:58 PM
Quote from: RevHappy on August 09, 2014, 05:43:50 PM
JohnP had a pedal box for sale about 2 or 3 weeks ago
I have everything else.
I even have a Spare LSD'd 02A handy.
Post by: RevHappy on December 11, 2014, 10:12:15 PM
Been enjoying the car ever since putting in the gearbox. Has been running like a trooper and is still always getting looks.
Heres a couple new photos(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Ftapatalk.imageshack.com%2Fv2%2F14%2F12%2F11%2F8244f317f79eb245b70cb63c5f13ce26.jpg&hash=476495cc0cff8f643a514e86f0eb095205199e33)(https://www.vask.org.nz/proxy.php?request=http%3A%2F%2Ftapatalk.imageshack.com%2Fv2%2F14%2F12%2F11%2F3af47acc2b42f57bec09534972249075.jpg&hash=62f61b860984159cdd60e6d77eb332702609709e)
Post by: RevHappy on October 08, 2020, 03:46:47 PM
Oh wow, its been a fair amount of time between updates haha. Anybody still use vask?
Post by: sneakertim on October 09, 2020, 08:53:37 AM
I have a look every no and then, but not much...
Post by: ranton-inc on November 25, 2020, 09:15:39 PM
Quote from: ziptie.nz on August 09, 2014, 05:09:41 PM
Funny that look what upgrade you made recently 🤣
Post by: RevHappy on November 25, 2020, 09:18:28 PM
Quote from: ziptie.nz on November 25, 2020, 09:15:39 PM
Haha, mk4 8v box. Missed it by that much.
