VOLKSWAGEN => Mk2 Golf - Jetta - Corrado => Topic started by: scrubber dub on October 11, 2017, 06:54:57 PM
Title: Mk2 k-jett radiator upgrade
Post by: scrubber dub on October 11, 2017, 06:54:57 PM
Just wondering if anyone has upgraded there mk2 radiator? bigger, better, larger? mine seems to run quite hot but that is not indicated from the thermostat as it doesn't work, runs sweet just seems hot after a run, any suggestions? cheers
Title: Re: Mk2 k-jett radiator upgrade
Post by: albert7550 on October 11, 2017, 08:35:04 PM
Try replacing the fan switch. For some reason they start kicking in later when they get old. This with a proper flush and water hose through made a big difference on mine.  Assuming your fan works.
Post by: scrubber dub on October 17, 2017, 05:07:46 PM
Yeh mine seems to come on when I pull up somewhere after a drive so will try what you suggested! cheers
Post by: luigi on October 19, 2017, 06:09:24 PM
You could try a mk2/3 diesel radiator, or use dual fans from a passat on your current set up
If you have an A/C model you can use the fan wiring to make a manual fan switch to regulate heat - need temp gauge to work for this
Post by: black16v on October 19, 2017, 07:21:26 PM
If the car is not modified then spend your money on getting it checked out and if there is a problem fix it. Don't waste your money trying to fix the symptom. Fix the cause. I'm sure the VW engineers got it right.
Post by: SG on October 31, 2017, 09:58:46 PM
^^^ This.
When was the last time the coolant was flushed?
Don't want to spend money? What colour is the coolant? If it is brown, google it, flush it thoroughly, do it yourself it's not that hard.
If your car has the original hose clamps, something like this:
https://www.amazon.com/OTC-4525-Cable-Type-Flexible-Pliers/dp/B000F5JM0O/ref=sr_1_2?ie=UTF8&qid=1401498586&sr=8-2&keywords=hose+clamps+pliers (https://www.amazon.com/OTC-4525-Cable-Type-Flexible-Pliers/dp/B000F5JM0O/ref=sr_1_2?ie=UTF8&qid=1401498586&sr=8-2&keywords=hose+clamps+pliers)
Should come in handy.
It's pretty important the thermostat works, or do you mean the gauge?
