September 10, 2010, 12:24:59 PM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: Volkswagen Group News
   Home   Help Search Calendar Login Register
Pages: [1]   Go Down
  Print
Author Topic: Mystery Fuel Leak  (Read 398 times)
typ53
Offline Offline
« on: February 02, 2010, 11:04:03 PM »
So the Quattro (1990 RR) has a fuel leak somewhere in or near the fuel tank.
It's noticeable as a fuel smell in the cabin after it's been on boost for a bit and after the car is shut down it seeps from somewhere under the fuel filler flap.
I don't know if it's a leaky fuel cap seal or a perished seal or perhaps the fuel tank is getting pressurised.
Does this sound familiar to anyone?
Any ideas on where to look to try and track down the cause?
Logged
The Fleet:
Orange Roughy:'90 16v Corrado
The Other One: '93 2.8l 100 Quattro
John Stone
On the lookout for a warm weather pattern
Offline Offline
« Reply #1 on: February 03, 2010, 06:29:17 AM »
Not sure about leaks around the fuel tank, however there have been documented cases of leaking fuel lines, get underneath and check them, have a good look around the fuel filter too.
John
Logged
86 WR
98 A4 quattro hack
2001 Passat
GlenT
Offline Offline
quattromad
« Reply #2 on: February 03, 2010, 08:06:47 AM »
May sound silly, but make sure the fuel cap is on properly.
Had the same symtoms on mine years ago. Fuel smell in the car, small amount of fuel leaking out from the over flow drain from the filler when it sloshed out from cornering.
Turned out that the last time I filled up with petrol the forecourt attendant (one of the very few times I let them do it) didn't put the cap on properly.
Logged
typ53
Offline Offline
« Reply #3 on: February 03, 2010, 09:56:08 AM »
Thanks guys, will try those suggestions and report back.
Logged
The Fleet:
typ53
Offline Offline
« Reply #4 on: February 03, 2010, 09:50:04 PM »
Tightening the fuel cap helped somewhat, it's still seeping out a bit but not nearly as much.  I'll try and track down a suitable seal for the cap and go from there.
Logged
The Fleet:
colingrant
Offline Offline
« Reply #5 on: February 05, 2010, 09:47:26 AM »
Yeah the caps leak. If I park on an angle with a full tank it dribbles a bit. Likewise on hard cornering with a full tank.
Logged
blue 0v
Offline Offline
« Reply #6 on: February 06, 2010, 08:43:32 PM »
My black QC leaks were the the fuel filler pipe goes in to the tank, around the welds.so if you fill over half tank it smells.found the leak when I was at station filling and having a nosey around the tank.jay
Logged
blue 86 UR quattro (zero Valves & cylinders)
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.8 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
